Who makes a digital numeric A/F gauge
Moundir
Ny
Car belongs to Paolo, he should chime in if he sees the thread.
Paolo Castellano
Elburn, Il, USA
I have seen them on different cars, but the one I saw that I like is on this car doing the 209mph! Who makes this? and any idea how much?
http://www.chicagosupercars.com/media/video/209mph.avi
Ab, that is the FJO wide band O2 sensor with display. I think it is about $750.00.
I would go with a dual wide band O2.
Call the guys at HP freaks.com. They have great prices and great service.
Venom 1000TT
AZ USA
I just put this one in my car from AEM, costs around $400.00. You only get one O2 sensor but I welded a **** in each exhaust side & just keep a plug in the one side when I want to switch to read the other side.
[image]https://prostreetonline.com/pso/pages/details.asp?productsku=30-4221[/image]
Cudaman
USA
I will help out Venom1000TT with his image
Cudaman :usa:
Cudaman
USA
This is mine and 1Tony1 from the "land down under"....Australia
It also has data logging
.Inbuilt data collection (wideband, RPM and two A/D channels) with RS232 output.
.Works down to 11 Volts for battery use (bike and kart usage).
.Narrowband output (with adjustable stoic point) provides sensor signal for ECU.
.Linear voltage output (Vlin) zero to 5 Volt, with AFR = 9 + (2 * Vlin).
.Free-air re-calibration adjustment and precisely adjustable stoic voltage setting.
.Reverse polarity and inbuilt fuse protection.
.Positive power indication (greed LED), and Ip enabled indication (red LED).
Cudaman :usa:
FirecatF7
