In today's world a FMU is like stone knives and bearskins. The biggest two problems are that FMUs bump fuel pressure linearly with boost, but fuel flow goes up as the square root of pressure, so you are either too rich at low boost or too lean at high boost. The other problem is that high fuel pressure is ******* injectors and fuel pumps.
What you really want is to adjust the computer for larger injector duty cycle under boost, which the VEC-2 and AEM can do. Yes, both are more expensive than a FMU, but both are a lot less than a damaged engine.
