Will an UNUSED SCT 9550 pull a check engine code, or do I need the dongle installed?-
alwayscode390
STL
My car has been throwing a check engine light if I let it sit for awhile, and usually turns itself off after starting the car 3 times (or maybe its the mileage, but seems like a certain number of startups will fix it).
I have a SCT 9550 that I have never been able to use because my engine tuner doesnt have the Viper "dongle" to UNLOCK the unit.
Can I use the SCT hand held to check the code, or will I have to buy an OBD2 reader?
What OBD2 reader works ... ANY of them? Do you have a recommendation?
The car is a 2001 GTS ... thanks :) ---
WDW MKR
Alabama
Re: Will an UNUSED SCT 9550 pull a check engine code, or do I need the dongle install
Most SCT handhelds can pull codes on any matching model of vehicle, but can only alter parameters on the vehicle to which it is married.
A
alwayscode390
STL
Any basic OBD2 scanner will read and clear codes right?
Looks like my tuner doesnt want to use my SCT and its up for sale ... Thanks :) ---
Atom
