KaiPL
Has anyone else had this problem?
My passenger side window doesn't get below the convertible top when you shut the door. It drops a 1/4 inch when you activate the handle, but needs to drop about 1/2 inch to clear the top. The result is that the window hits the outside of the top and the door doesn't close properly.
I'm thinking that a change to the window programming would be the quickest fix, just programming the ecm to drop the window an extra 1/4 inch. Called the dealer, and they don't know what to do. Said they can't reprogram the ecm themselves.
Any one out there have any similar experiences?
Kai
Kai
