Dilute the dishwashing liquid in some water, pour it into a spray bottle and spray the tint.
Wait for about 5 mins, use dryer to gently warm the tint and starting from a corner with the razor pull an edge. While gently warming the tint and spraying the solution between the tint and glass use your fingers to pull on the tint. Use the blade on the glass whenever it is too hard to pull or to remove small pieces.
Be sure to use a BRAND NEW razor blade. Any prior use (even for shaving) can dull or raise points which can scratch your glass. I would even use a fresh blade for the second window.
go over to your local AutoZone, they got tint remover, they are cheap, sweet, easy and fast, try it and you will like it. i done it so so many times.......
