In a previous thread I explained that I had removed the air cleaner filter and the car set a CEL. It also seemed as though the pcm was limiting the power. I attached my scan tool and it showed the code set by the air filter removable. In addition, there was a second code that indicated the throttle control was limiting the power..
I removed both codes and the car seemed to run fine. As a check I had a local SRT dealer put his Witech scan tool on the car. Here is the strange part, he could not see the PCM history and therefore the two codes I had removed. The second interesting item was that he saw several chasis codes that I could not see with my scan tool.
