phiebert
I just posted a possible coolant leakage problem with my car but it reminded me of a story. A while ago a friend of mine had a car, I can't remember what kind it was, that developed a bad gasket leak apparently letting in a lot of water into the engine. He told me that eventually it got so bad the car wouldn't run but that before it got that bad the car had tons of extra horsepower. He claimed, and scientifically I guess it makes sense, that just enough water would get sucked into the cylinders, mixed with the air and fuel and add to compression. The theory was that there wasn't enough water to stop the explosion but enough to increase the compression, with water being harder to compact than air. Basically turning the water to steam added dramatically to the compression and power.
So if this is possible, wouldn't there be a way to harness this by adding water injectors that sprayed just the right amount of water into the cylinder to do the same. You could fill up with a bit of water at the pump as well and it would have the added benefits of increasing horsepower, reducing fuel costs, cooling the engine and possibly even assisting the emissions. Thoughts?
