04 SRT Help!!
ASASN
Tifton, Ga. USA
Hello!!
I just recently purchased a 04 Blk SRT, 965 miles now, K&N Fiter Kit, rear cats have been removed..that's about it!
My queston is.....I have a "squeal" under deceleration, at least more evident, after the car has come up to operating temps!! I can accelerate and not hear it, come to a complete stop and idle, hear very little of it in the front of the car, but, if I lay on the ground and listen, I can hear it clearly......drivers side is where I was laying!!
So, I thought it was the idler pulley, changed it, not the problem.....am I looking at the cam/balancer bolt issue?? I did a search, and most had that problem under cold conditions which has me thrown!!
Other than this issue, I gotta tell ya.....I love it! It's a hell of a car, I just wanta get this solved so i can go drive it some more!!
Thanks for the help!!!
Mike P.
A
ASASN
Tifton, Ga. USA
Hey Kelly!!
I thought about that, but would the filter kit make that kind of noise from underneath the car at idle...hood open??
What could i do to determine if it's the kit or not......is this a common problem? This kit was on the car already when i bought it!!
Thanks!
kmg99
Portland,OR
Check out the K&N filter thread from this summer. One of the other members diagnosed a similar squeal problem from the K&N fitting holes being undersized. Easy fix, just a couple of drill operations for the blow molded part of the K&N assembly.
Brian E
Granger, Indiana, USA
Have you actually put a wrench on the bolt for the balancer and torqued it?
If memory serves me, you need a 13/16 socket and torque it to 130 ft. lbs.
GR8_ASP
I have experienced it as well. Without question it is the K&N tube due to undersized PCV and idle air ports. Check the other threads for the size to open them up. Once I did both ports the noise went away completely.
A
ASASN
Tifton, Ga. USA
Hey guys........
Did a search, found out what to do to the kit, did it.......runs like a champ!! No more "squeal", completely gone!!
Thanks for the help, off to have some more fun.....NOW, I really do love this car..unreal!!!
Mike P.
FirecatF7
