06 Coupe fuel door
First Strike
California
Recently removed the fuel door on my 06 coupe to have finished in black chrome. Upon removal I discovered that there is a ground wire that apparently was connected to the inside of fuel door. Does anyone know exactly where this ground wire should be connected. Thanks
ASPIRATIONS
Park City,Utah
F/S,
Mine was connected to the lowest bolt on the fuel door.....I had to take off the pass. side panel in the back hatch and reach my hand in with a 10mm? wrench.. The nut fell off when I was taking the fuel door off because its not connected to the inner part like the rest of them..Thank goodness I was able to just reach under the inner fender and track it down:omg: Hope that helps,Kevin
ASPIRATIONS
Park City,Utah
N/P :2tu:I did it awhile ago so my mind is a little fuzzy but there is the regular nutplate bolt there then you put that ground on then the other nut. Watch out because that ground wants to spin as you tighten the nut too.Now I bet I have you confused..Any other questions just let me know.. I just powder coated black the part that flips open and it looks great on my Bumblebee..Kevin
ROIII
