Wavetrac stub axle
Venamous54
USA
Good day all,
I am a new GEN 3 owner. 2003 to be specific. I am considering a Wavetrac differential due to my diff being *****. My question is....are the Wavetrac stub axles the same as OEM? Is the unit plug and play for the most part? Thank you in advance for any information the group can provide
Venamous54
USA
Thank you for responding Ramtuff. Will they fit the fit the OEM cv axle? Do you know what the difference is?
Steve M
Dayton, OH
The difference in the stubs is how they are retained internally with the Wavetrac carrier - that part is different than OEM (where the grooves are for the circlips, and possibly the spline count). The external side where they connect to your OEM axles is the same.
Venamous54
USA
Thanks for the reply. They are on back order but since its time to put it up for the winter it's no big deal. I appreciate the info from everyone.
Venamous54
USA
The Wavetrac I ordered comes with stub axles. I ordered it from Vividracing out of Arizona. It was on sale. 200.00 off.
04Mamba
Ohio
Be prepared to wait on the Wavetrac. I have been on back-order since April of this year (also ordered from Vividracing). If you plan to change the gear ratio to the 3.55 set up, I would suggest going through Unitrax for the complete parts needed - outstanding service! Wavetrac will only fabricate the diff's in batches of 20 or 25 - so when that request for orders is met, they will proceed with fabrication. Wavetrac's newest projection is middle to late January of 2025 (direct email from Wavetrac to me in November). However, this date has been constantly moved back since April. Best of luck waiting in line.
Venamous54
USA
Thank you for the information. I have already purchased a 3.45 gear set. Where is Unitrax out of?
Staff online
performancechass
