I forgot to add...
Try switching cars and give us the results.... If he is your good friend I don't see why not!
Thanks, I think I have a better picture now. I assume Doug either installer a different pulley or a blow-off valve. That would make quite a difference.
I'm sure aerodynamics played a part at those high speeds too.
i heard someone say the best time for a stock srt with a paxton is 11.3 or so. i think i'm probably a tenth or so faster because i have comp tires.maybee i will go with a header and no cats.for a little more bottom end. i like loud sounding stuff anyway
he really hates getting beet.
hey plumcrazy since you have a dlm s/c coming soon why dont you pull his phone # out of my ass and call him and ask him what is the best time he has ever heard laid down on a gen3 all stock with stock paxton and safe boost.then after you called and asked him can you shove his # back up my butt just so i have more stuff to pull out.thanks
Remember, just because one car has a better coefficient of drag (cd) than the other, doesn't mean it is the more aerodynmaic. This is a misunderstanding by many.
Aerodynamics = cd * frontal area, NOT just cd.
Viper:
.39 (cd) * 19.3 sq ft (frontal area) = 7.527
Z06:
.34 * 22.3 sq ft = 7.582
As you can see, the Viper really is the more aerodynamic car, although by a very small margin.
It is the gearing, the weight, and the redline of the Z06 that makes it more supreior in the acceleration department.
Having both cars, I am willing to bet that it will take a Viper about 500 rwhp to just run even with a stock C6 Z06. This car (Z06) is very, very fast for a stock car.
whatTF would you get 1.7 rockers for when the car comes with 1.73?????? He said the Z06 traps at 130. there's no exhaust or a mopar pcm in the world thats gonna make the viper trap at that speed with a STOCK PAXTON sc. You should know whatTF your are talking about or ****he really hates getting beet.
You can give him carrots instead ;-)
Sorry, had to...
Buddy, you need to open up the exhust, you don't need Dough Levin to tell you that. that engine is CONSTIPATED, eating too much but cannot expel the by-products.
Get Mopar Off-road and you are all set. I recall someone in here saying that it even comes with O2 sims.
From there on, I'd go with 1.7 Roller Rockers, and a ECM tuned specifically for a SC engine.
Don't let them sucker you into more expensive, less H.P. mods.
Sorry, had to...
Max
I am looking at both of my dyno sheets right now. I dynoed my bone stock Viper and Z06. This is a very general analysis as to why the Z06 is quicker than the Viper.
Let us look at the upper rpm range as that is where races will take place.
Viper @ 4,500 rpms = 400 rwhp
Z06 @ 4,500 rpms = 370 rwhp
Viper @ 5,000 rpms = 425 rwhp
Z06 @ 5,000 rpms = 400 rwhp
Viper @ 5,500 rpms = 430 rwhp
Z06 @ 5,500 rpms = 430 rwhp
Viper @ 6,000 rpms = 420 rwhp
Z06 @ 6,000 rpms = 440 rwhp
Viper shifts. Back @ 4,500 rpms = 400 rwhp
Z06 @ 6,500 rpms = 454 rwhp
Z06 @ 7,000 rpms = 450 rwhp
Z06 shifts. Back @ 5,500 rpms = 430 rwhp
Repeat with the Viper shifting....
As you can see, when the Viper shifts at 6,000 rpms, the Z06 will really start pulling away while having an ~54 rwhp advantage. When it is time for the Z06 to shift, it is still making more rwhp than the Viper at its given rpm. Remember, I am solely going by my stock Viper dyno (437 rwhp @ 5500 rpms) and my stock Z06 dyno (454 rwhp @ 6500 rpmws) Some cars can be weaker, some can be stronger.
This is just a quick, high-level analysis.
Remember, this is not considering the gearing nor the weight in which both characteristics favor the Z06.
