08 break squealers and changing to stop-techs
ViperGal
Dripping Springs, TX
Was reading over the SRT engineers posting about changing an 08 rotor to that of the ACR and they mentioned removing the squealer ...
I am wondering if this also applies if you change out stock 08 rotors to Stop-Tech rotors?
Thanks!:drive:
RTTTTed
I would expect that if you spend the money to buy new lightweight rotors you'd also be spending the extra money to buy better/more suitable brake pads, like I did.
Ted
Nader
New York
I think they mentioned you can change the location of the squeler to the inboad side. Check the post again.
Thanks!:drive:
Art 138
Davie,FL
Those of us who chose the Eurotecks had to do the same. I just snipped them off (the squealers) on the side facing the rotor hat. Otherwise you will get a ticking sound every time the edge of the squealer hits the high point of the hat.
MikeR
You WILL have to remove the squeelers. They are riveted to the pad. I took some needle nose pliers grab on to them and wiggled a couple times and it broke off nice and clean. If you dont remove them, you will scracth the hat of your new rotors.
Nine Ball
Houston, TX
My EBC reds and Euroteck rotors do not squeal. Try changing pads first, break them in properly.
ViperGal
Ted
What kind of pads did you buy?
The stock perform quite well ... for some reason it never crossed my mind on the squeallers before I read the SRT chat.
YellowViperSRT10
Florida
Just remove the squealers. I honestly like the stock pads. They are very good for street and even some track use. Or do like I do. I run stock pads on the street (sometimes the track too). But otherwise i change to a race pad for the track. Most other street pads out there specifically the low dust ones do not have enough bite like the stock pads do on the street.
rcl4668
Oregon, USA
I switched to the Stoptech 2-piece aerorotors on my 2008 and retained the same pads as stock. I do not know if my Viper tech had to remove the squealers but so far after about four driving schools I have had no problems or visible damage to the hats or rotors.
/Rich
SnakeEye
Austin, TX
StopTech 2pc Aero slotted/drilled rotors and stock pads perform just fine and removing the squealers isn't a problem.:drive:
RTTTTed
Less unsprung weight has small advantages in acceleration and braking. It does have bigger advantages in handling however. All 2 piece rotors come slotted and/or drilled for better brake performance as well. They usually come with curved cooling vanes in the rotors as well.
Ted
rcl4668
Oregon, USA
Hey all --
I checked my Viper with the 2-piece Stoptechs today for the "squealer" people have been discussing. Are the squealers little "U"-shaped sliver clips that look like they are attached to the pad itself? If so, I think mine are still attached but they do not appear to be causing any damage to the Stoptech aluminum rotor hats.
I will be bringing my car in for an oil service soon and will ask my Viper tech about this issue.
/Rich
Kkustelski
