Hi here in Mesa Az
I have a 1995 rt10 dodge viper issue I was wondering on ideas .it sat for about 1yr with a full tank of gas and some sea foam .issues I’m having it was having a hard time starting I would have try 3 or 4 cranks and some time I’d have to dis arm the alarm ,horn would start to go off after multiple try’s cranking the car over even when I did the key on off 3 times to prime the fuel pump after it started in ran fine
So I decided to change the battery it is a costco battery I did try a different auto zone gold battery nothing changed I ran some cleaner chevron tech Ron and and some injector cleaner after doing that car started to run rough so I siphoned the gas and put new gas in it. Chevron 91%.
Still running rough so here’s a list of what I’ve done and it’s still running rough
New standard champion plugs
New plug wires
Oil change
New fuel filter
Both up ward O2 sensor
When I turn the key I do here the fuel pump activate I’ve put a screw driver to the fuel injector and there clicking correctly I’m wondering if they could be clogged or if there’s any other sensor that could be causing this
What I thought I had done with to much fuel cleaner was foul the plug but they where not fouled I don’t seem to have any check engine lights on the dash board
If there’s any club member in Mesa with an obd1 reader that would be great
If you guys have any ideas or thoughts I’d sure appreciate it
Thanks so much for any ideas and help Rob
New plug wires
Oil change
New fuel filter
