Kumho Ecsta V-700s are the best all around.
Tell me more about the Kumho Ecsta V700s. On tire rack it has this warning:
Kumho Ecsta V700 tires must be shaved to 3/32" - 4/32" tread depth for any autocross or track use in the dry.
Kumho advises that the Ecsta V700 DOT-legal competition radial must be shaved prior to use in dry conditions. If this tire is not shaved, excessive wear may occur causing the tire to wear to the cords prematurely in a localized area.
Tire heat cycling will not prevent the excessive localized wear of full tread depth tires but will continue to enhance tire consistency and wear on shaved tires.
The Ecsta V700 should only be used at full tread depth (6/32") for wet track and wet autocross use.
Kumho Ecsta V700
One reviewer on there said they were better than the Hoosiers and lasted longer. But when I searched for Kumho 345/30/19 it said No results from Kumho brands at all.
But are the Kumho / Hoosiers good for street use? All of my driving is street, should I just go with the PS2s?
