5245322 PCV Grommet NLA / Substitute
Suregrip391
Niagara Falls
Hi Guys, I always try to do as much homework on my own as I can, does anyone know if this is the correct Dorman PCV Grommet for a Gen 2 Viper? I would like to have one on hand for the day I need to pull my intake and change my T-stat. Specifically for my 97 GTS
OE Number 5245322
Dorman Number 42064
if Anyone can confirm the fit and size of an original as they do look the same? Open both attachments to see…..
Chrysler Corporation has used exactly the same grommet for every car in their line since 1967. The ONLY difference for the Gen 2 is that it has a double-male barb pushed in from the backside. The Dorman part is good to go. They also make a replacement for the hose from there to the PCV valve. It may be too long, but that's just because in '98 Dodge did away with the standard valve and went with an orifice restrictor in the tee. Just cut the excess off.
Do you track your car at all, or just street drive?
Suregrip391
Suregrip391
Niagara Falls
Hi Dean, thanks for the info here, just street driven…..I’ll have to see about tracking that part number down for the hose….
efnfast
Canada
Did the PCV grommet hole change in dimensions during the Gen 2 run?
I have my intake manifold off so figured I'd change the grommet as cheap insurance while I'm there. I bought the standard "fits every Chrysler since the beginning of time" grommet - NAPA 6301073 - and while it does fit the hole, it's a snug-but-loose fit. I can move the grommet around (back/forth) about 1/8'', and with just a little of force I can collapse it into the hole (that was fun to retrieve).
The one Viper Parts Depot sells is the same as the NAPA one.
My current grommet fits tight, absolutely no play, so the only thing I can think of is either dimensions changed along the way or the grommet starts as a loose fit then swells (but that doesn't make much sense since every pcv grommet i've ever used is a tight fit from the get-go)?
efnfast
Canada
I did - my research suggests there's only 1 grommet. However, in some catalogues the OEM number goes back to just 2001-2002 Vipers, and in others it goes back to 1994.
I've never had a pcv grommet with a snug-but-relatively-loose fit before, so it makes me think that maybe the dimensions changes for 2001-2002 cars.
Perhaps, but I have no certain knowledge of that. I would strongly doubt they would modify the casting for engine blocks that had only 2 years remaining production life. Go to two different auto supply houses and get grommets to try.
efnfast
Canada
I've got 3 "different" grommets from 3 different sources - they all measure the same and the markings look the same, so there's probably only 1 manufacturer.
When you install a PCV grommet in your block, would you characterize it as a tight fit (i.e., does not move around the hole) or a snug-but-loose fit (i.e., can be moved around the hole about 1/8'' without any effort)?
efnfast
Canada
Definitely not my experience - all 3 I bought just slipped in (while putting my original one back in was a SOB)
I asked Viper Parts Depot and they insist there's only 1 grommet
So yea, that means either later gen models have a different sized hole (seems unlikely), somebody modified mine (seems even unlikelier) or maybe along the way the manufacturer of the grommet changed the sizing of it. Perplexing!
