Chuck 98 RT/10
More is not always better. In this article a rally navigator suffered severe lacerations on both sides of his ******* due to the 6-point harness resulting in testicular herniation. I haven't heard of any similar injuries with 5-points but even if there were the object of the submarine belt is to hold the lap belt in place, it doesn't need two straps to do that.
WARNING Gruesome pics.
http://www.sciencedirect.com/scienc...70c5948b24a9d5b23e21239ef7d&ie=/sdarticle.pdf
We suggest that the mechanism of injury in this
case of the testicular herniation involved a deceleration
force which caused traumatic compression
of the ****** against the ***** bone, combined with a
degloving injury to the scrotal skin due to the
arrangement of the crotch straps of the harness.
Whilst the harness used here spared the occupant
more severe injuries, it is of concern that this type
of injury occurred despite the harness and the three
layer suit. The minimum safety standard for harnesses
in cross country racing is two shoulder straps
and one lap belt,1 although most drivers prefer a
minimum of a four point harness involving straps
coming over either shoulder and up from the waist
to join in a central quick-release coupling. In this
case a six point harness was used: a greater number
of points of harness contact should equate with
greater restraint. The added crotch strap, fixed at
points under the seat, connects to the coupling at a
single point (see Figs. 3 and 4). The crotch strap has
the advantage of preventing the occupant sliding
under the belt (‘submarining’) and spreads the force
of impact more evenly over the body in the event of
a crash.
