Some good reading lately.....
Random thoughts on this thread:
1 - Based on what I've read, go with the stock Paxton kit. It will be more than enough for you (and most people) at this point. It will also be very dependable and much cheaper than going to the dark side - 900 + rwhp. It will work better on a race track too.
2 - Not sure what some of you guys mean when you say that a S/C car is going to be "exerting a whole lot more effort" at the top of each gear. Power does build in a very linear fashion with rpms in a S/C car and there is definitely a strong finish to each gear as the supercharger spins faster. I think a S/C car is generally easier to control for most when compared with a TT car.
3 - TT cars tend to "hit harder" (make more torque) lower in the power band and depending on the Turbos and the tuning, may not continue to produce power in a linear fashion all the way to the rev limiter. I know some tuners are making this situation better using AEM and other tuning computers by limiting boost in lower gears. You won't have to do this with a S/C car.
4 - I would guess that a properly set up TT car making 800 rwhp at peak would out run a good running S/C car making 900 rwhp at peak provided both can get the power to the groud. There is more power under the curve in the TT car and the S/C cars suffer from parasitic power loss due to the power needed to run the S/C.
5 - I've seen too many Viper owners go for a Paxton kit and then continue to make changes like adding boost (without forging the internals or upgrading the fuel system) to get good dyno numbers. These cars usually detonate and self destruct.
6 - I'm about at the power limit on the street with my 925 rwhp Paxton car. I had to make many very costly changes to get the power to the ground and keep the car together, so don't think you'll make big power cheaply for long with the S/C. Examples of additional costs are forged internals, heads, cam, roller rockers, headers, new fuel system, AEM, bigger radiator, quaife diff, stronger clutch + pp, Motons, Kumhos, 1/2 shafts, etc. etc. New motor mounts go in shortly along with a water/**** injection system to keep intake air temps cooler. Bad gas can be a problem too, so you may want knock sensors.
7 - You'll have to deal extra heat regardless of which way you go. The more HP / TQ you make, the more heat. I wouldn't recommend trying to track a 900+ rwhp car in the summer. You will melt things like spark plugs, engine parts, etc.
Recommendations: Base Paxton system for 650 rwhp or if you want more, 800 rwhp TT. Stay away from the dark side if you can.
Good luck,
Dan
