AB Wires Loom kit?
1994viper
Toronto, Ontario
I just purchased a set of wires from AB for my Gen I, and they are on its way. Now I am wondering, what do you guys use to hold those in place? I am not sure how thick those wires are and if stock wire holders will do? Where and for what I should look for? Thanks
VIPER BAZ UK
ENGLAND
Or you can get the newer style clips from Tators and they just fit..... Bit tight!!!! But work just fine 3+ years now....
Few pics here.....
badasp2
I have a gen1 with AB wires and the fit my oem looms?? Don''
V10 PWRD
Culpeper,VA
Just put my new red AB's on about 2 weeks ago and had the same question. I called Adam and he said not to worry that the OEM looms worked great. He was right. Not a problem and they look great. What a difference with new plugs and wires. Idles very smooth. I'm assuming you're changing the plugs too.
costanZo
Haverhill, MA
WOw Baz, you're engine looks amazing! I eventually plan on restoring my engine to look pretty too :D
Although, I want mine to be mixtures of Blue/White/Black, how much would something like this cost to make it color-coded like yours? I'm not doing a Super Charger like you, just wanna dress it all up under the hood like yours.
JohnnyViper
Massachusetts
my oem looms works perfect, a tip before you start the wire install remove the looms, the screw out, I broke one removing a plug and it could have been easily avoided
JT Miller
