ABS warning light after battery change
ViperDad
Any thoughts on the cause and correction?
Thanks,
Max
2006 coupe
bluesrt
did you try to drive it, then shut it off and re-check?
ViperDad
Yup, but just in case, went and did it again but same result.
Omaha NE.
Check it with a scan tool and see if there is any indication whats wrong, maybe that just clearing the light will take care of it. We had a few cars that just seemed more finicky when changing out dead batteries.
Bobpantax
Miami
You probably have a speed senser that has gone bad. It's not that common with Vipers but it happens. It is a quick fix that should take less than one hour to change out the sensor.
ViperDad
Issue resolved, apparently just needed sitting overnight.
Max
Bobpantax
Miami
Do what Mark suggested and put a scan tool on it anyway. When the speed sensor starts to go bad, the ABS light can go off and on intermittently. Sometimes it stays off for days then comes back on briefly, etc.
frankthedude
