Accufab Throttle Bodys
v10kingsnake
south jersey
they are shiny so if that means something to you then great. otherwise unless your pushing massive amounts of air via forced induction through them they aren't worth their weight in the metal it took to form them. Hey, they do make good paperweights.
01ACR/VIPER
01ACR/VIPER
ORLANDO
OK OK...I get it:D they look good.:2tu:
RAYSIR
Salem, OR
If putting larger throttle bodies on your intake is not increasing performance by allowing more air to mix with more fuel then why do you guys put freer flowing air filters and smooth tubes before the throttle bodies?? Remember that SCCA restricts the air intakes so the Viper is competitive. Bigger throttles open it up. Same on any stock engine with a throttle body even a carb, more CFM until too much. Everyone sells bigger ones. More air, more fuel then hit the limit then supercharge it.:2tu:
kc651
