ACR oil filter adaptor....
Edward 96GTS
Monterey, CA
Does the acr have a different oil filter adaptor than a 96 GTS?
And would it make do it your self oil changes easier?
TIA
Janni
Raleigh, NC, USA
Different oil filter adapter - ALWAYS runs oil through the cooler. You sacrifice air conditioning ability in stop and go traffic to cool engine oil better.
Looks the same - makes no difference, good or bad, in oil change procedure.
tommygun
YES IT DOES HAVE A DIFFERANT ADAPTOR, BUT IT DOES NOT CHANGE THE LOCATION OR ACCESS IT IS ONLY DIFFERANT IN THAT IT DOES NOT HAVE WHAT THE BOOKS CALL AN "AIR CONDITIONING SHUTTLE VALVE" WHICH LIMIT FLOW THROUGH THE OIL COOLER UNDER CERTAIN TEMP. CONDITIONS.
tractor1996
