Added a diffuser blade
treesnake
St.L
Doubt if it has any real additional effect above the original two diff. blades but...
Mike at XVIPERS gave me a couple blades and I thought I would try it. Kinda' makes the back look wider and the diffuser blades are more visible from the side. Looks like they have always been there...IMHO
dave6666
You are right about the aero effect probably being minimal. Let alone the SRT's diffuser to start with. To have it be really functional you have to get to that farm implement size whereas the flat plane would be the most rearward surface on the car. Not a very **** looking part except at the race track. So the SRT is kind of a balance between function and looks when it comes to the back door view.
ROCKET62
Has Left the Room!
Phoenix, AZ bye-bye IOWA
Treesnake - you're kidding us right? You post about adding a diffuser blade instead of giving us an update on your TT? Very disappointing :)
MoparMan
Las Vegas, NV
Looks cool. Great color combo on that coupe, BTW. :D
ROCKET62
Has Left the Room!
Was I the only one that looked at this picture and thought that you need to get some blue coolant :confused: :rolaugh:?
WOW - can't wait to see this beast in action. Look forward to the post that states you finally have it on the road.
Extra diffuser blades do look good btw although it's hard to beleive that they can make the back of the serpent look any wider than it does already.
More later...
tractor1996
