madman
You can't install CT and leave crossover. It comes in one piece per side. They have other exhaust which accommodates crossover. But I don't see a point of leaving that radiator in the car.
I have the CORSA Track with RT (metal) h/f cats ... the CORSA is coming off, and I am replacing with a Mopar Race sytem, but keeping the cats.
"would that make it sound less like a UPS truck?"
yes
I just read that if the Mopar Race Exhaust is installed, the Race Controller and Camshaft are needed - really????
How about the Mopar Street Exhaust?
No. You don’t need the Mopar Race controller or Mopar camshaft if you install the Mopar Race exhaust but because the race exhaust eliminates all the cats, you will need some sort of tuning to get rid of the error codes and tune the car to run without the cats. Otherwise, you will get codes and the car will run very rich.
Sorry but you are incorrect my friend.
The A/F mixture is controlled by the first O2 sensor (upstream), therefore it makes absolutely no difference whether you have one cat, no cat or ten cats.
Yes there will be a "check engine light" when the O2 molecule % in the exhaust is the same in the upstream and in the downstream (after cats) sensors. That is why an O2 simulator is needed (or reprogram) on the second (downstream sensor) when the cats are removed.
Cheers!
If you don’t have 02 simulators and if you have not tuned the ECU for running without the cats, the check engine light will be on. The higher flow due to not having the 4 flow-cutting cats will lean you out a little and the ECU will see this and counteract, causing the car to run rich. It won't be running pig-rich but still it will be running a little rich. Again tuning will take care of this.
Cheers.
[/b]
Cheers.
[/b]
Ok I didn't say everything was wrong. We are both in the same page regarding the O2 sims.
Your statement above is off. There is no reason why the ECU will "counteract". Engine Control Unit is there just for that, to control the engine function. If your car is running lean, the injectors will fire longer until this misbalance is fixed. Of course, we are talking about an otherwise stock car, not a monster that needs extra fuel pumps, bigger lines, bigger injectors, etc.
Bottom line. Take out the cats and install O2 sensor simulator. Reset computer, and the car will run just fine.
Cheers!
ViperBob
I do have the Mopar Race Exhaust (no cats) w/K&N filters. The engine was running rich but after a DC performance reflash of the ECM the car ran noticeably smoother/faster.
Carleton
ViperBob
Carleton
SRT-10’s will benefit a lot, not only HP number wise but overall ride quality wise from a custom tune after bolt-on mods like exhaust, intake, cam, etc......
AMAZING !
Our first testimonial that an exhaust / intake can improve the RIDE quality.
This thread clearly illustrates why EVERYONE here is an expert. Newbees beware, "I read it on the VCA Board" is NOT the gospel truth you may think it is.
AMAZING !
It’s obvious that I wasn’t talking about suspension, springs, wheels, tires, etc.
Yes, it was pretty obvious, nobody here thought that you wre refering to the actual suspension.
But I still disagree on the engine running rich after installing off-road exhaust...
Let's agree to disagree!
We already have one Viper owner saying that his car was running rich on the dyno after cat deletion and race exhaust with no tuning.
You don’t have to agree with me. Just believe in the dyno.
Put any otherwise stock SRT-10 with cat deletion, race exhaust and/or high flow headers on the dyno and look at the graph.
At WOT, the cal provides a measured fuel and spark based on the inputs. Exhaust back pressure or f/a ratio are not included. Thus there is no WOT adjustemnt to fueling resulting from improved flow. Thus improved flow decreases the f/a ratio.
Headers or cat delete should both result in increased exhaust flow and decrease the f/a ratio. Any other result is illogical. The fact that at WOT the stock cal is quite rich, and therefore still rich after minor flow improvements does not change the physics. More air flow, same fuel equals lower f/a ratio.
The ******* contest is getting old.
