RobZilla
So recently I replaced my tranny, clutch and all components etc. After about 800 miles, there goes the clutch. So I thought it was a simple bleed issue. Tried that a couple times, no work. Switched to the old Master Cylinder, same problem. Even tore out the tranny again and went with another Slave Cylinder, still no work.
The big problem to begin with was changing gears and going into gears from the start. By the time we started working on it, I was locked out of all gears with the car running, but not when off (shifts smooth).
After all that changing and work, Now the cluch hydraulic line must be all gone cause starting the car in a gear and she wants to drive off. I'm clueless now and could use some real good advice fast.
PLEASE HELP.
PLEASE HELP.
