What? you don't enjoy playing "Hindenberg Roulette"?![]()
On a similar note, does the fuse disable both airbags? I'd like to give my little niece and nephews a ride, but my 97 doesn't have passenger side disable.
Where can you order this?There was a kit from Dodge to add an airbag switch to 96 & 97 Gen 2 Vipers.
NHTSA approved it
Make : DODGE Model : VIPER Year : 1997
Manufacturer : DAIMLERCHRYSLER CORPORATION
Service Bulletin Num : 083799 Date of Bulletin: NOV 12, 1999
NHTSA Item Number: 6089800
Component: AIR BAGS:ON-OFF SWITCH ASSEMBLY
Summary:
DAIMLERCHRYSLER CORPORATION IS NOW OFFERINB AIRBAG ON / OFF SWITCHES FOR SELECTED VEHICLES. *TT
Service Bulletin Num : 081798 Date of Bulletin: DEC 30, 1998
NHTSA Item Number: 603153
Summary:
SUBJECT REGARDING AIRBAG ON - OFF SWITCHES. *YC
An important item was how the kit grounded the airbag when the switch turned it off.
While a mis-deployment would be very rare, just pulling a fuse or disconnecting leaves the circuit vulnerable to an electric static discharge that could deploy the airbag.
also, the kit only allowed you to disable the pass. side airbag - not the driver's side.
This lets you disable the driver airbag:
Service Bulletin Num : 970919083297 Date of Bulletin: SEP 19, 1997
NHTSA Item Number: 54423
Component: AIR BAGS
Summary:
AUTHORIZED AIRBAG DEACTIVATION FOR MEDICAL NECESSITY. *YC
NHTSA approved it
Summary:
Summary:
Component: AIR BAGS
Summary:
