ALL MOTOR BUILD!!(Pics)
fe4snake
Florida
Yea it is a tiny bit rich...lol. But I have a wideband to monitor the a/f and will adjust.
Also...the valves are set at 0.018 on both the intake and exhaust.
Steve, that sounds great. :headbang:
What is your a/f reading.
I can tell you that after my tune, my a/f is at 13.1 to 14.1 under idle and 12.6 to 13.6 at full throtle.
2001 GTS
Charlotte, NC
We are thinking the injectors I have are too big for what I am doing. So GTSR 001 (Steve) is sending me his 42lb green tops and should be back up and running tomorrow night!
vp97
Lewisville,TX
For your valve lash, you might need to add more when cold. Most specs that are published are for an iron block and heads. I have had to set them hot in the past, one side at a time.
2001 GTS
Charlotte, NC
She is running flawlessly now! Have a dyno time set up for next week...so we will see what it puts down soon!
2001 GTS
Charlotte, NC
Thanks guys! It's feeling faster and faster the more I drive it.
Anyone need some 65lb injectors? Is there any buyback Simms?:D
2001 GTS
Charlotte, NC
UPDATE!!
So far with NO timing added yet....
590rwhp/614rwtq
So it should be over 600rwhp EASY when I start bumping the timing!!!
Then I might try some race gas and see how far I can take it!
fe4snake
Florida
Those are very good numbers!!:headbang:
I bet she sounds very mean.
What was your corrected A/F numbers?
2001 GTS
Charlotte, NC
ok so i watched the dyno vid your car is running great verry impressive BUT ITS TIME !!!! with that engine now drop in a supercharger and put the 65lb injectors back in your looking at 800-850hp
11.5 compression isn't a little high for forced induction?
plumcrazy
ALL OVER
jeez, that sounds sweet
I noticed you tossed the VEC....and went with the split second. runs better i assume now ?
2001 GTS
Charlotte, NC
Got about 1500 miles on the build and I couldn't be happier.
Had the throttle bodies synced correctly over the weekend and it drives like a dream, I feel it is even better than stock with a ton of power to boot!
Couldn't have done it without the help of a lot of good people on here!!!
Steve
MDoe8
Northern Colorado
Looks great! Looks like it is a blast to drive. If you ever need more power, just slap some laughing gas on it. Love the car!
ViperGear
