2001 GTS
Going to be dyno tuning on Friday April the 3rd at 7pm at Mayhem Motorsports in Raleigh, NC if any of you guys are close by!
... we figured out that the valves had too tight of a lash ...
Lash too tight = valves hang open and the car misfires b/c the cylinders are not firing.
Steve's car looks awesome in person. Pictures don't do the rims justice. The car _wants_ to run. And even on 9 cylinders it sounds AWESOME. The cam selection was perfect. It is a shame that we couldn't run it on the dyno, though. i mean we could have... but we'd be missing 10% of the power.
Steve - you'll get there. the car has sooooooooooooo much potential! Glad you made it home safe!
Joseph
Good meeting you the other night. Guess I need to pick me up a vec for old yellow so I can get you to tune her too![]()
Well....just got home from Raleigh with no dyno numbers
Had to do a lot of troubleshooting and at the end we figured out that the valves had too tight of a lash and the VEC3 ONCE AGAIN is not putting out a signal to injector #2. So have to send it in again to have it looked at.
On the way up we were put 1-1.5hrs behind because of Charlotte bumper to bumper traffic then 1hr from Raleigh we had a blowout on the trailer!! So it started out bad and just kept going down hill.
The shop even had the audacity to charge me with 4hrs of dyno time ($150/hr) and we didn't even strap down to the dyno!!!!
So special thanks to Joseph Dell for taking his time to help me out all night, he is second to NONE!
Bobby - Don't get rid of the split sec just yet! I'm going to give the Vec one more shot, but that sounds like a good alternative.
Thanks for all the support guys! I know it will be badass if we can get by all the bs. haha
Update:
In the process of changing the injector clips. That's pretty much the last bit to be wrapped up. Sean Roe hooked me up with a new slave board for the VEC3 (It was completely fried!!!!). That's why no signal was going to the #2 injector.
So not long before it is completed. My only issue now is an oil leak coming from what looks like the rear main seal!!
Steve
Steve,
Why don't you just use the split second? I have a very similar setup as you, and I am using the split second without any troubles so far.![]()
Well if your going to go with an oil leak, go big! Rear main!!
Keep us posted.
