The red tab slides to the right. I found that out AFTER I destroyed that piece of crap connector. Idiots whoever designed that piece of crap. The other guy that needs to be shot is the genius who designed the clamps used to hold the hoses on. Simple screw/nut ratchet type are soooooooooooooo much easier to take off.
As for the monkey clamps, I replaced them all with real ones when I put it back together yesterday.
As for the red tab connectors, I agree wholeheartedly ! PITA!
As for the clamps, they are the "correct" engineering solution. They apply the specified clamping force equally around the hose without damaging the hose. However, they are a pain to take off if you don't have the appropriate tools.
The problem with the cheaper plain worm drive clamps is that people (including me) tend to overtighten them and cut the rubber. If you tighten it to where it should be, then you should go back every once in a while and retighten it after heat and cool cycles. The OEM clamp is designed to expand and contract along with the hose and tube and always applies a constant clamping force.
Why do I know this? I got ********** at taking those clamps off and on and did some research. I also had a leak due to a simple worm drive band clamp that I used. So, I then bought the proper tool, to remove/reinstall the OEM clamps.
There are
worm drive constant clamp force clamps available; but, a bit pricier than the cheap plain ones.
