Always check the obvious!
Venom 1000TT
AZ USA
Awhile back I posted I needed AEM tuning and thank you for all the replies. Well for some reason I figured I'd check the spark plugs. I went to pull the 1st plug wire off to get at the plug & it crumbled in my hand. (as did several others). My wires were fried! Some of the plugs were black(from running rich). So I put on these new plug wires called LIVEWIRES which are guaranteed up to 1400 degrees,(they come in different colors) and took the car out for a spin. Problem solved! Car's back to normal and Air/FUEL ratio is good. So always check the obvious things before commiting extra money/work!
Venom 1000TT
AZ USA
Yes it gets fairly hot. I checked it one time with one of those laser temp guns & it was over 500 degrees near the header/spark plug area. I got my wires from www.performancedistributors.com for around $150. They come in different colors too. They also fit very well over the NGK spark plugs where it was very difficult with the Mopar wires. I still put the bootys on as an extra precautionary device.
Venom 1000TT
AZ USA
Hi,
Mark, John H. actually gave them to me but I know Jon B. at Parts Rack has them for sale also. They are just the cloth boots you pull over the plug wire at the spark plug end. Good luck!
Jamie
Venom 1000TT
AZ USA
As soon as the rain stops! But I do have a painting appointment on Oct.31st to redo the back end.
sham5430
