Bugman Jeff
I'm working on getting my '97 back into shape. When I got it, the hood was way out of whack. I got my doors set, then set the door-hood gaps. They're not perfect, but are acceptable for now. Now I'm trying to set the hood-fascia gap, and I'm stuck. While the drivers side lines up well, the passenger front corner of the hood is high, very high. With the latch adjusted as far down as it will go, the hood is still 7/8" higher than the fascia. The hinge isn't hitting anything and doesn't look bent. I can't see a way to get the hood down further so it looks like I need to move the bumper assemble up but the holes are only slotted side to side, and don't look like they'll allow enough adjustment to go as far up as I need it to. The corner of the hood has been repaired, but it is shaped correctly(certainly not 7/8" off), and the inner skin doesn't look tweaked.
I've read just about every hood adjustment thread, and didn't come across any solutions. My service manual isn't much help either. Am I missing something here? Is my only option to slot the bumper mount holes to allow the whole bumper/fascia up on that side? Any advice is greatly appreciated. Thanks for the help.
