1DumpedViper
- Joined
- Sep 19, 2005
- Posts
- 340
- Reaction score
- 0
Well I had part of the afternoon off today and on a whim called Todd at A&C to see if he could fit me in at the last minute (3:45). I got there and he wanted to make sure there wasnt a problem with the front tires (the balancing). So he swapped them out and we went for a ride and it wasnt the tires. He noticed the back rear left tire was REALLY low when it was sitting on block of wood as we had the car on the jack, so he checked and there was 11LBS of pressure in the passenger rear! The crazy thing is that the tire didnt even look low sitting on the ground. Once we filled it up the car drove straight as an arrow! I could not believe the difference. We waited 5 minutes in between checking the pressure again and the tire lost 3 lbs, so I will be taking a trip to americas tire.
As far as the ride. We were at full firm at all 4 corners and it was HORRIFIC! Todd put them 8 clicks back from full firm in front and 2 back from full firm in the rear. It rides much better. I am still not totally happy with the ride for a set of $3200 coil overs, so I will get a jack and play with the settings when I have more time, but for now the ride is better. Heres the bottom line and end of the story when it comes to the KW's, if your looking for a decent ride on a hammered Viper, these arent the shocks for you, period! A normally lowered car would do fine. For my application I need either Motons or possibly the new shocks coming out from the former guys at Moton.It really is amazing how bad ass Motons are (Of course they better be at that price)
I just wanted to give a huge thanks to Todd and Herman at A&C. It took Todd about two hours to adjust everything, change out tires, test drive, and set the settings. Not only did he not charge me a DIME, He actually gave me $20!!! (I forgot my wallet at the office and didnt have enough gas to make it back to the OC). How many shops will not charge you for two hours of work and then actually pay you!
He also took me for a ride in a black Supercharged monster with gears, I'll be polite and just say I had an accident in *******! I was dead set on a Heads/Cam, but after that ride I'm not sure. Thanks again Todd, I'll be back in Jan. for Motons, Headers, Exhaust, Tune, Filters, gears and to have you go through the entire car.
Mike
Mike
