Freddy,
EUG........ put down the crack pipe and step away from the computer
you need to read my post on page 2 and then come back with a reply to that. addresing the LS7 engines, exhaust gas reversion and piston to valve clearance issues with cast pistons are not gonna be solved with minor mods. good luck making 600 rwhp N/A and getting this motor to pass emissions.
you are the one who has no clue what you are talking about
Man, you found the wrong person too call out on modding late model Vettes! lol
I know almost everything there’s to know on this subject.
First of all, it’s a fact 427ci LS1/6 motors have been making in the neighborhood of 600rwHP for some time. This is NA, street motors that run on pump gas. This is a
FACT. If you have a problem with this, I suggest you do a search on CorvetteForum and you’ll find specs, dyno charts, track numbers, etc. I’m not gonna bother wasting my time on this for you…
Now, any idiot that knows anything about motors knows that LS7 is a much better motor than LS1/6, mainly due to 12 degree heads. Also lightweight bottom end (thanks to titanium rods) doesn’t hurt making additional HP either, neither does dry sump.
So you look at all these
FACTS it’s easy to see that at
a minimum LS7 will make ~600rwHP with bolts-on + heads/cam job. A job like that costs $10-12K tuned and installed for C5s/C6s at a reputable tuner. I don’t see why it would be any different for new Z06.
Now I never mentioned anything about passing emissions, but since you brought it up consider this:
A lot of states now have “ODBII check type” of emission testing. In case you don’t know what it means – a computer is plugged into ODBII port and it checks for any emissions related codes.
No codes – passed.
What this means is that pretty much any size cam, no cats, etc. can easily pass.
All you have to do is program out the codes that would be normally set by computer (this is done during the tuning process) Very easy
the reason the new LS7 engine is getting such big gains from headers is because the cylinder heads have a poor exhaust port. the intake port is awesome. the intake port has 2.20 valves and flows a whooping 348 cfm @ .600 cam lift. the exhaust port has a relatively small valve at only 1.61 inches and flows 220 cfm @ .600 cam lift. the exhaust to intake ratio is a dismal 63%. in order for this engine to go beyond 500 rwhp in a N/A state you will have to port and polish the exhaust side and install bigger valves. in order to run more lift on the exhaust side you will have to fly cut valve reliefs into the pistons. since the pistons are cast you might as well throw those in the garbage and get your self a set of custom forged pistons. the stock cam already has 20 degrees more duration to combat this flow inneficiency so a biiger cam won't get you much more than 25 rwhp on this motor unless you do the engine work that i have described. and so there in lies the rub. its gonna cost you sum $$$ to mod this engine to get 550+ rwhp in N/A state. if you do it right you can make 550+ rwhp N/A on premium pump gas. you may or may not pass emissions though.
And finally to address you specific technical details:
I don’t know where you got your info on the cam, but LS7 cam size is - 230/231 with .591 lift -
Source
Not sure what LSA is at this time…
You did get the right numbers for head flow -
Source
Now are you telling me that LS7 motor with such tiny cam and this outrageous head flow
will not pick up significant HP moving up to a bigger cam?
FYI - My heads flow:
200 132 117
300 194 172
350 220 196
400 244 207
450 265 215
500 288 220
550 305 223
600 314 226
650 327 227
and I make ~500rwHP with 244/244 .608/.612 114LS cam.
My car doesn’t even have 90mm TB and 90mm intake which LS7 has stock and makes a
HUGE difference on big cube motors (proven multiple times to show gain of another 20-30rwHP easily)
So now looking at all this data you’re gonna keep telling me that LS7 with MUCH better head flow will not make 550rwHP with stock heads and decent sized cam (say like mine)
Maybe it’s you who needs to put the crack pipe down?
P.S. Btw: what makes you say that bigger cam will cause valve to piston clearance issues? Is this just your
assumption?
Valve relieve you say? Take a look at this: LS7 pistion
P.S.S. Many people had their stock cast LS6 pistons fly-cut while in motor when they needed it for a large cam - no problem at all
________________________________________________________________________________
EuG re-read the article. the article states 2 different cam specs in it? the duration specs you mentioned and 230/211 duration @ .050. that bein the case its pretty obvious this article is suspect. the correct LS7 cam specs are:
intake exhaust
lift .591 .591
duration @ .050 211 230
LSA = 120
so again i still stand by my statements and assesments that bein that 550 N/A rwhp with the stock unmodified heads will not be achieved and pass emissions.
