Viper Blade
2000 ACR, 15000 miles. I was playing around with my car rolling it up through 3rd and 4th to 4500 rpm after a Viper club run. Couldn't get the spirited driving out of my system. Running quickly out of room I had to swiftly stop including downshifting and got a very large puff of blueish white smoke upon stopping. Never seen this happen before and I've owned the car for 6 years. I have read here that it could be valve seals or it is not uncommon to **** oil into one of the cylinders through the intake. Read quite a few posts on it. Just too eliminate a failing head gasket I checked the oil for water in it and for water in my oil. Everything was good. I ran a compression test and there is less than a 1% difference on the cylinders. The plugs all looked very good. Three plugs appear to be just ever so slightly richer than the rest. It's like comparing egg shell white to a slight, slight tan in a small area of the other 3 plugs. I checked for gas bubbles in my coolant catch tank while it idled. There are no leaks, drips, or errors. Exhaust smells clean. I Even opened the air cleaner and found no oil in it or on the filters. Then I got to thinking. I just had my oil changed. I checked the level and I was about a quart and a half over full. The oil level was completely covering over and then some the "FULL" lettering on the stick.
I'm thinking that the puff of smoke came from too much oil in the engine and it did get sucked through the valve stems. I'm not too confident on the oil through the air intake theory. Help me sleep at night, do you think it was just too much oil in the system and it should be fine now that I lowered it. I have ran it hard since then and nothing, no smoke at all. Engine idles fine etc...
By the way new Mustang GT's though spankable are quicker than you think. How would I know that?
