Flash1034
I got a good deal on bulk Mobil 1 15w-50 Motor oil. Any problems running that oil in my 2008 Viper?
Thanks,
Flash
Thanks,
Flash
SRT Engineers;2605564[/B said:]This question has come up a few times on this forum with some misinformation being passed along - Just for the record; 15W-50 will work fine in the 2008 engine. The only downside might be a slight drop in fuel economy (0.2 to 0.5 mpg if you can measure it or if you care!). The 0W-40 oil was selected primarily for the slight fuel economy improvement it offers and its broader operating range when compared to the older 5W-30 or 10W-30 oils. The 0W-40 is a superior product when compared to the 5W or 10W-30 oils.
The only caution is as Mark stated, make sure the 15W-50 is up to operating temperature in cool or cold climates before you run any moderate or high engine speeds (good advice in any case!). In some instances, the 15W-50 can actually improve cam control in new engines when the cam and valvetrain friction is high (for example use 15W-50 for the first oil change and the 0W-40 thereafter). The higher viscosity and shear strength improves hot oil pressure and provides more control force for the VVT system as a result. Certainly use the 15W-50 if you are on track often or in high temperature climates. Hope this clears up this question!
I got a good deal on bulk Mobil 1 15w-50 Motor oil.......
Awesome info, thanks! I was worried 15w50 might cause too much cold-start wear for street use.Certainly use the 15W-50 if you are on track often or in high temperature climates. Hope this clears up this question!
PROOF POSITIVE that these guys LURK here...and that they give a damn....... Thanks
