Anyone have take-off Top Feed Fuel Injectors?
Cape Coral, FL
I figure someone may have a set laying around. I will consider any top feed injectors (Std. Bosch/Ford length) up to 53 pounds or so, prefer 34-42 pound. Can be saturated (high imp) or Peak & Hold (Low Imp) but prefer P&H.
Perhaps someone has a set taken off a Roe SC or something of the like?
Venom 1000TT
AZ USA
I have ten. These #'s written on them. I think they are 53lb: Ford XL3V-A5A, 927, 280 150 558. Make an offer. pm or email me at [email protected]
Cape Coral, FL
Green Tops should be 42 pound.
Can you measure the impedance accross the coil? I believe those will be 12-14, but not 100% sure.
Mileage?
Venom 1000TT
AZ USA
Sorry to sound like an idiot but how do you do that? :dunno: The tuner took these out and replaced with 650cc's. That's all I know. I'm not very mechanically minded. They have about 3,000 miles on them.
Mr Hemi Head
Bluemont VA USA
ohm-meter will provide a resistance reading but not impedence. Impedence measuring equipment is beyond anything sold at Radio Shack.
Cape Coral, FL
Whoops... you are correct, forgot that they are both measured in ohms. I was actually looking for the resistance number in ohms, though its impedance will follow suit as a high resis. Inj is a High Imp, and a low resis. Inj. is a Low Imp.
Joseph Dell
Atlanta, GA 30338
don't laugh, but when i needed some, i went to the mustang forums (www.corral.net/forums) and looked in the classifieds. I had no trouble finding someone to sell me 8 30lb injectors. and then i had no trouble finding someone to sell me 2 more. oh yeah: high impedance i think.
just my .02...
JD
Cape Coral, FL
just my .02...
JD
nope... not laughing. Half the injectors around are Ford Motorsports it seems anyway. I'll check it out over there too.
Cape Coral, FL
whats the difference between high impedance and low ???
High Imp. are called "saturated" injectors, while Low Imp. are called "Peak and Hold" Injectors. Saturated injectors fire with about 1 amp of current, and are held open with about 1 amp of current. Peak and Hold Inj. have a much beefier coil, and are fired at 4-5 amps, and then within a couple ms of opening, are reduced to one amp. Effectively, they Open MUCH faster, they are prevented from overheating during static conditions by the 1 amp "hold" driver, and also close faster because they are less susceptible to being slowed during closing by electromagnetic induction due to their low hold-open current. generally larger injectors will be of the P&H variety.
P&H injectors can be run in a saturated circuit by using resistors, but they effectively become Saturated injectors as such, and have no P&H properties... in some cases, they may be slower than a true saturated injector. Saturated injectors can also be run in a P&H circuit, but their P&H functions are greatly reduced as they have their own internal high-resistance, preventing a full 4-5 amp firing. They may gain a little speed by way of the current reduction, but thats about it.
Generally, its best to stick with the correct injector, resistors are just a cost-cutting measure as P&H are generally cheaper to buy in high-flow injectors. If you REALLY need a HUGE injector (over 60-70 lbs), get a true P&H driver, and run them correctly. There are excellent P&H drivers on the market that will turn saturated signals into a true 4-1 P&H signal, and make sub-1ms injector firing possible. For example, a stock saturated Viper injector idles at about 6-8ms. I have run 96lb P&H injectors on an SRT w/a P&H driver at full fuel system pressure, idling at ~.8ms without a problem. (also note, the rough calculation is 3x the injector size, but the pulse is about 1/10 that of the saturated injector- thats how much faster a P&H responds than a saturated. A saturated injector run at .8ms would not even open fully if at all, thats why idle quality would be so horrible.)
Puntacanaviper
