ANYONE having TROUBLE with TEFLON valve seals.
TOOOFST
Barrington,il
We have Issacs GTS with a few leaking seals.They only have a couple thousand miles on the new heads/cam package.Think we'll go back to the old rubber!
What are you using that worked for several thousand miles or so?
Go Fast For Life
This is common with teflon seals. Try using viton seals if you have changed valve springs or rubber with the stock springs.
dansauto
gillett, pa, usa
yep, garbage. A good friend of mine told me to use OEM's instad. He is a mechanic for over 30 yrs, never had good luck with the teflon
tractor1996
