97fatboy
Posted in VCA classifieds. I will also have a carbon fiber set shortly, but its still installed. I have a custom set on the way.
YES BlknBlu is right. The window switches from a Gen III will not fit on this shifter bezel. The guage bezel will work fine.Just an FYI. I know that the 08 cars ahve a small difference in the fit on the console piece. The window switches are sunk in a lot more and do not quite fit, however on the aftermarket Dodge ones they seem to be universal. Not sure about the other years.
Bruce
That's a Great Idea Labtec! Thanks, did it tighten down well are the switches moving at all?The switches will fit if they are modified. Basically if you look at the switches you will see the bits that need to be trimmed. You do not need to trim the console if you use small spacers as I did. See my notes and picture @ http://forums.viperclub.org/threads...arbon-bezel-and-console?p=3149192#post3149192
