Are T&D's and Mopar roller rockers the same?
J DAWG
MS
Are T&D\'s and Mopar roller rockers the same?
Mopar # P5007049 and T&D's. Are these the same. Does one manufacture for the other?
Does anyone use the Mopars? I assume the same issues apply as far as pushrod length is concerned.
John
J
J DAWG
MS
Re: Are T&D\'s and Mopar roller rockers the same?
Thanx Mark.
Now I just need to find out which pushrod length to use on my car.
fe155
San Diego,ca
I put the 1.7 T&D's in last month on my 2002 , it comes with a measuring tool
and 2 sizes of washers for adjustment . I was able to install them without use of the washers and also used the stock pushrods . I also installed the ones that have needle bearing on the roller tip as an option. about $200 extra.
I believe i spoke to sheldon at T&D , he said the adjustment end is preset a certain number of turns and although about one turn is recomended for contact
with the push rod a half more or so wont hurt as long as the oil hole is not blocked . After the install , i cranked the car over with the plug wires off
until oil flowed off the roller tip of each one . Installed the covers started the car and has been quiet ever since it started.
1TONY1
Dalton Ga. (Chatt. Tn.)
Needle bearing roller tip should be standard ???? Anybody else heard of it being an option ?
SUN RA KAT
Guest
From the Roe Racing site -
T&D Shaft Rocker Arms
T&D Roller Rockers are the preferred rocker arms of Caldwell Development, builder of the factory Viper GTS-R engines. Available in 1.6, 1.65, 1.7 & 1.75:1 ratios. Please allow up to two weeks for delivery when not in stock. *Needle Bearing Upgrade Available for Roller Tips. Please indicate Roller Tip Type.
Needle bearing upgrade downgrades your bank account $205.
Jack B
NE Ohio
FE155:
You were lucky maybe, the measuring tool doesn't work with the Viper. You have to manually find the geometric center by trying the different washers, that, establishes the correct length push rod. The stock rods do not always work. If the stock rods end up being to short and you turn down the adjusting nut over 2.5 to 3 turns that is where you can shut off the oil.
Vipermed 97.01
Tampa Fl. USA
Actually the tool will work on the Viper but only with the cyl.head and valve springs removed,as that is how they recomend the install
BigCarrot
Dallas, TX
Wow, that would be a whip! Remove the heads and valve springs to install them?!
