belanger header fitting problem
nismobrown
wales, GB
can anyone give me advice on the following. ----- I fitted a set of belanger headers and the driver side outlet pipe is resting on the frame where it bends to connect to the cat.
the passenger side is central to the cut out of the frame.I tried to jack up the drivers side mount with no success as it seems that a lug on the mount is stopping it from being raised. Any ideas of how to adjust the mounts to correct the problem?
thanks.
VIPER BAZ UK
ENGLAND
Dave can you drop down the passenger side a little to raise drivers......
Mine was the other way round...
Baz
Larry Macedo
Sanford, FL
I would try repositioning the engine first since most of the engines we encounter are canted a bit in the compartment. If that doesn't work, we have shims that can be installed under the mount which will help you with your installation.
