Big brake ?
jojogts
Guys would a stop-tech big brake kit for a 01 02 abs equipped viper fit my non abs 2000gts? If not is there anything out there that would make it possible to fit my car.
J
jojogts
Yea I'm looking into buying a used kit, just seeing if I could make it fit.
SoCal Rebell
Mission Hills, Ca USA
The '01 & '02 stoptech 4 wheel Big Brake package will fit a "00, I used to have an '00 and '00 stoptech system will not fit a '01/'02 Viper if you run 17s in the rear (which I did for better slip angle) without modification to the bleeder screw.
J
jojogts
I'm running 19,20 so clearance isn't a issue just wondering if I need any different brackets or other parts to make it work.
Chuck 98 RT/10
tampa, fl USA
The Stoptech kit comes with everything needed including brackets. Since you're buying used make sure you get everything. Another option worth looking into is Toms rear brake upgrade.
But since you're running 19s you should go with the SRT upgrade.
