The Center Force is as Dan say's, and the Spec is off my list. The RPS is grabby and will allways have a bit of chatter, but not all the time. Much loss of drivability in a way. But you do get used to it.
Carbon/Carbon coming soon, answer to our prayers.
It is the absolute solution.
Center Force is very drivable, but really will not last on heavy modded cars. The centrifuagal weights do in fact work. This clutch clamps down very well, but I really don't like much about them.
RPS is tough, as it uses a 6 puck disc, and will not slip, pedel pressure is only slightly more. It is a some what short life setup, but is rebuildable, for a very low cost. If you drag race this clutch will lung forward in second in a very controlled maner. The oem unit doe's in fact slip going into second, unde full load. But a car with street tires can actually benifit from this. The RPS really takes constant practice to get the best out of it.
Aggresive take offs are a bit challanging with the RPS setup, as well as normal takeoffs, to keep the chatter down.
Segmented flywheels are the way to go.
Just to let you guys know, I'm hooked up with one of the sharpest clutch guys in the country. I can get you what you need. Carbon/Carbon may be worth waiting for. The Viper deserves, and needs this.
You guys need anything to do with clutches, give me a call. My new number is 423-288-3881 or 817-988-4760 I really have put some time in on this subject.
Last but not least, the oem LUK unit is a very nice unit, and super low in cost,(through me) but it is not for the drag race minded. You can get good results when running oem tires, as they put very little strain on the clutch. Drag radials will smoke an oem clutch easily.
Clutch builders have left the Viper community standing, as the production numbers are so low. But they are comming around.
The LS1 and Vette community have many wonderfull setups, that handle huge amounts of power, and never give trouble.
