Sonny 00 GTS ACR
Hi Ron,
I would bet money that the smoke didn't have anything to do with your computer trying to "learn your new driving style". If you notice this happen again, check the tube that connects the crankcase ventilation to the back of your air box (drivers side I think). The valve covers are vented in the front near the bottom and with sustained high RPM runs followed by hard braking some of the oil finds its way forward into the airbox. At that point, the oil is ingested back into intake, through the engine and out the exhaust, ie., the black smoke.
A remote reservoir with new hoses and fittings is one way to address the problem. I have seen small breathers that can be fitted right to the same connection points where the stock hoses exit the valve covers - I think Archer sells them.
If you are really serious and/or are planning to do a lot of road racing, the best way to clear up the situation is to eliminate the source. If you plug the existing valve cover vents and drill new holes in the top center of the valve covers, run new hoses to a remote reservoir/breather, then the movement of the oil during track maneuvers will not be a porblem.
Good luck and keep road racing!
