Blower motor and resistor
TowDawg
Chattanooga, TN
I read through the threads on this, but want some opinions.
When I got my car back tonight after it had been sitting for three months, the air was blowing for a few minutes and then stopped. Nothing would come out on any setting. The motor was pretty hot, so I assumed it had locked up.
I just pulled the motor out and it smells a little funny inside the housing, but it spins completely free with no issues.
I pulled the resistor and sure enough, the tab has come un-soldered.
Here are my two questions:
1. I thought it would still work on the highest setting even if the tab had come un-soldered, but it wouldn't work on any setting. Does this mean the resistor is toast even if I solder it back? Gonna give it a shot anyway.
2. The tech said the A/C needs recharged, but his machine is messed up. I would think this wouldn't have any effect on the blower system though. It just wouldn't be able to blow cold air. Am I wrong here? Could the A/C not being charged have caused this issue?
Cape Coral, FL
1. The motor is probably bad, and caused your resistor to pop. The fuse may be blown as well. I would not advise repairing the resistor, just replace the resistor and motor as a pair. I have seen bad motors pop new resistors, and repaired resistors end up being failed shortly after internally.
2. Nothing to do with it.
Nader
New York
Just replaced mine. Same issue. I changed out the motor and all is good.
T
TowDawg
Chattanooga, TN
Well, I soldered the strap back on my resistor and put everything back together. Nothing. Didn't even turn on for a second and then blow. Working with VPA on a new motor and resistor now.
As far as the motor, has anyone had one just burn up or go bad, but not lock up?
Like I said earlier, it smells a little funny, but it spins freely with no problem.
Cape Coral, FL
Yep, I have... that's why I posted to replace both. A resistor that is cooked with a free spinning motor is a dead giveaway.
stike9993
