Brake line plug
Chuck 98 RT/10
tampa, fl USA
Does anybody make them so I can work on the caliper without the brake fluid draining? I suppose I could use the rubber hose method but it seems to me a plug would be less messy.
ruckdr
Renton, WA USA
Break the lead out of a sharpened (tapered) pencil, and twist it into the line; should work just fine.
Janni
Raleigh, NC, USA
I would suspect that in the "pick-a-nut" assortment at Lowe's, you could find a suitable rubber plug / cork stopper for a brakeline.
Tom F&L GoR
Wappingers Falls
How about remove the hollow bolt from the end of the brake hose, use any solid bolt that passes through the metal fitting with the copper washers?
C
Chuck 98 RT/10
tampa, fl USA
That might work. Knowing me I'd lose the hollow bolt when I went to re-attach it.
rharon
