Nadine UK GTS
I have tapped larger breathers into the top of my valve covers and blanked off the OE cover breathers (that puke oil). My 37K mile '97 Coupe has quite a bit of blow-by. I no longer have the block breather / PCV valve with the Supercharger application. I know I need PCV to pass emissions but this is not an issue for me at the moment! I am making a collection bottle (with oil separator) for the new valve cover breathers, and notice that there is a little fine oil mist that's vented, but the main vent product is a caramel-color clear fluid (probably quite acidic!). I read the posts a while back with interest on fitting in-line PCV valves to the breathers (a quality Harley type application was used). What I am wondering is what does the GenII engine favour? Whether or not to just put a small K&N filter breather on my collection bottle, or to put a vacuumed line to the collection bottle, and connect this before the TBs (I have cone type filters and 3" metal tubes). I think if I connect into the port on the SC intake tubes after the TBs, it will give big fluctuations in vacuum pressures with closed / open TBs that may not be in correlation with when the breathers need vent vacuum assistance? If I do tap the breathers back into the air intake making more a closed system, it may help to draw all moisture from the engine (since venting openly through a filter I have noticed the top of my dip-stick starting to make a little rust).
Any comments, knowledge or experience would be gratefully read, so I can be happy I'm doing the best breather system for my engine! Thanks
