The airbox has what I believe are larger intake ports (with BSR stamped on the inside). The airbox had a real Rube Goldberg affair with some lind of aluminized "dryer" hose from that larger "BSR" connection to the throttle bodies, which had blue silicone "adapters" (about an inch of silicone hose) to allow the larger diameter hose to work on the TB side.
What I need is a "flared" "smooth" tube (different size ends.
2-1/2" to fit the outside of the stock throttle body (as per the usual)
2-7/8" to fit the OD of the BSR airbox tube.
(I know I should get the larger throttle bodies to match and then the larger smooth tubes would work like a charm, but I am not ready for that).
Can someone PLEASE help me out or direct me to a vendor that would have such a hose with different size ends??
THANKS!!
THANKS!!
