Built engines and performance packages
DPViper
Indianapolis, Indiana
I have been looking for a GTS and I have come across a number of nice cars with "built" engines and performance packages from Hennessey (can I say that here?) and others. How do you evaluate these type of cars? Is there a reasonable way to verify the engine is actually improved? Should these cars be more or less desirable? Thanks for the comments. Doug
1BADGTS
Get a motor build sheet -dyno sheet .Even with this the only way to really tell if the bottom end ect has been done is to pull the heads and pan .
RedEnuf93
Lancaster, PA
Here is a good example:
eBay Motors: Dodge : Viper (item 250291545942 end time Sep-12-08 13:55:28 PDT)
How is a buyer supposed to verify the engine work was done as described? I'm sure it is better/safer to buy a stock car (and then mod is yourself) but you save a whole lot of money if you buy a car already modified. Thanks
Buying that one is like buying a pig in a bag. No way of knowing what John actually put into it (or didnt?) and its not worth dismantling the whole thing.
plumcrazy
ALL OVER
might wanna ask a few texas owners if they know the car or owner. and start there. unfortunately that tuner does have a rep for NOT doing what he was paid to do in the past.
SylvanSRT
Sylvan Lake, MI, USA
meet owner at a chassis dyno and get a printout stock hp #'s are fairly well known and if "built" to whatever degree should have greater hp than known stock nums
G
grcforce327
Guest
The website states 605rwhp and 605tq.Take the car to a neutral dyno and spin it!:2tu:
tractor1996
