Can I drive GTS with side sills off
kernie
Atlanta
They guys that put on my cats last weekend did
a really crappy job. At one point they got the
torch a little to close to the body and the seam
has separated a small bit.
I want to take this to a shop and have corrected,
but I'd rather leave the sills at home. Can I
drive the car about 10 miles with the sills off?
Martin D
Dunwoody, GA USA
Kernie,
Go for it... No problem with the Sills off.
I have on word for you....McIntosh.
Call me if you want the experts to make the fix.
Regards,
Ron
Indianapolis
<FONT face="Comic Sans MS">Antidotal evidence leads one to believe that driving without the side sills leads to a droneless experience.
If you do drive without the sills, please let us know if it's true.....</FONT f>
Will
San Mateo, CA USA
I wouldn't worry about it. I drove the GTS sill-less when I had the side sills repainted. Just watch your legs and don't wear shorts.
Will
K
kernie
Atlanta
The did weld, problem was they used a torch
to heat the joint where the cat and muffer
connected.
In heading the joint, the plastic above it
got too hot and a seam appeared where the
two pieces join.
FirecatF7
