I can have them made...what is the diameter and length? I will also have them made with a sligth angle. Is 10 degrees good? I also know that the inside needs to be smooth also.
You just need to make sure that there is enough slack in the rubber or urethane ends of the tubes that connect to the throttle bodies and the airbox. That's why I use turbonetics tubes.
Kent, I have heard of damage ocurring from cutting tubes too short exactly down the alley that you speak of.
