Edward 96GTS
With the help of a friend, we will be changing the oil/filter, brake and coolant fluids. Are there and tips/tricks anyone can share to avoid common pitfalls?
Called dealer to buy a new radiator cap and he said there might be a difference between 96 GTS and 97 GTS caps. The 97 is described as "pressurized", the 96 cap has no description in his catalog. Any advice?
I have a 4 post lift.
Do I need to pull the rr wheel to bleed brake system?
TIA
TIA
